Hplc
Is it ok to keep assay and purity method same or not?
If you're able to validate it, it's valid :D
Generally speaking, it's usually easier to have separate methods for assay and purity as you can optimize the respective method according to the special needs.
If possible, I'd go for separate methods. At least when it's going into routine usage. During development, a single method for both might be fine.
In total there are 18 users online :: 2 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 16 guests
