IC for quartanary ammonium salts
Is anyone out there do quats by IC?
Currently on a Dionex NS1 column using 35% methanol solvent MSA eluant and chemical supression.
Would be intersted if anyone has experience of Quats on other Dionex columns with lower solvents and CSRS supressor.
Methods that I am proposing here are not based on Dionex technology, but may be you are not totally stuck with it.
http://hplcmethods.com/compound_080.php
http://hplcmethods.com/compound_161.php
dpr,
What quats are you working with? What is your eluent: just MSA, methanol and H2O? You should be able to get by with less methanol if you change to a more highly hydrated anion such as acetic acid.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
