Chemstation data fault
Hello everyone,
I have chemstation version B.03.01
This may seem like a silly question but when I go to the data analysis page the chromatograms do not appear in the data analysis list. Instead, I have to manually load the signals individually by going through the option (File>Load Signal). I wrote a new method but this did not solve the problem. My other methods do not have this fault.
Do you have any suggestions? I'm assuming I ticked the wrong option box....
Thanks, Peter.
it doesnt seem to be a fault. You can select the data file from the list and click it to open it. Its normal, else you can try higher version of chem station.
Users browsing this forum: Google [Bot] and 1 guest
