volatile fatty acid analysis
I'm given aqueous samples of VFA (volatile fatty acids) which are pH 6 ish. My standard used to be just about 5 mg/mL of the acids
in water and hence, about pH 2. When I adjust the pH of my standard to pH 6 the response factor goes way down! Duh I guess it
would.
Should I acidify all my real samples and if so, what acid and what pH? I'm using a PEG type column.
Or, can I esterify? I have tried a few alcohols but the alcohol always seems to coelute somewhere around the Propionic acid ester.
I have seen in the literature, extractions of free acids into ether using nitric acid.
I have also seen direct aqueous injection using sulfuric acid.
I don't remember the details. Perhaps a trip to the library or a search on the internet might be of great benefit.
best wishes,
ROd
VFAs in water are a hardy perrennial on the forum - have a look through the archives. What are you injecting ?, an extract or the aqueous matix ?, or headspace ?
injecting aqueous samples containing short chain fatty acids. Results are useless because the pH
of the samples is sometimes below and sometimes above pKA'a.
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 24 guests
