Chemstation "mark identified peaks"
Hi all
I have a question regarding Agilents Chemstation
Im fairly new with this softwere and use it mainly to identify compounds.
So when im using i identify each peak in the chromatogram.
So my question is:
Is there a way to make chemstation mark the peaks i have identified?
With a tick mark or a dot or something?
This will make it alot easier to knoe how far i am with the identification of the peaks.
Or is the a smarter way to do this?
It would be best if there was a way to make the tick mark, but other tricks are also welcome.
Best regards from Denmark
In Data Analysis, select the menu 'Graphics > Signal Options'. It will have peak labels as 'RT' (retention time). Select 'Compound Name' and the identified peaks will have the retention time and compound names labeled on the chromatogram.
Thank you very much for the reply :)
Users browsing this forum: Google [Bot] and 11 guests
