Storage solvent and cleaning for HILIC column
Posted: Fri Jun 08, 2012 12:39 pm
I had one TGKgel Amide 80 column as HILIC column. But i am not sure what solvent system should i use to store it for longer time. May i know what solvent system should i use to store?
Another problem is i notice the pressure is increase/ usage. Is the column has been contaminated? May i know are there any ways to clean it? I have no confident to reverse flush..
Thanks.
Thanks.
