m/z 240.23 contaminant?
Hi there,
I am trying to get rid of a contaminant from my LC/MS system, but I figured it might help to know what it is. I could not find the mass in our common list of contaminants (PEG, phthalates etc.)
I'm running a simple H2O ACN gradient with 0.1% formic acid with positive ESI (Q-TOF).
Any clues?
Thanks.
From John W. Dolan May article (http://www.chromatographyonline.com/lcg ... ail/773766):
An extra peak, that is not related to the sample itself, in a gradient run typically arises from one of three sources:
late elution from a previous chromatogram
carryover from a previous injection
contamination of the mobile phase (ghost peaks).
I would suggest you to read the rest of his article, I think it woudl help you to fix your problem.
peak might be related to column bleed
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
In total there are 36 users online :: 0 registered, 0 hidden and 36 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 36 guests
