Please help me Identify this Compound!! :)
I have an unknown synthetic cannabinoid that I need help identifying.
My base peak is 373, while the other major peaks are 298, 232/356, 144, 169, 115, 284. (from greatest to least)
If you happen to have a MS to go along with your guess, could you PLEASE send it to me at annie.smith0903@gmail.com. Thank-you!!
Annie
We have a software named Tal-Aviv Molecule Identifier that could invert the molecular ions of EI mass spectra via isotope abundance analysis into elemental formula. Read more on this software at
http://www.avivanalytical.com/Isotope-Abundance.aspx
Thus, if you analysed this synthetic cannabinoid compound with an Agilent 5972/3/5 or 7000 and trust that the m/z=373 is the molecular ion you could send me the file and I will write back ASAP the list of possible elemental formula
Amirav
Email: amirav@tau.ac.il
Annie,
This mass spectrum is not readily interpretable as is.
We need to know,
1. the ionization technique EI/CI/ESI/FAB/MALDI etc, and mode (+ve or -ve ionization),
2. derivatized or not,
3. reaction from which derived (starting compound, synthetic route/reagents etc)
Even then it may not be interpretable !!!
JMB
JMB is right on. To add to his remarks...
Is this GC-MS or LC-MS??
Do you have CI at your disposal?
Software might give a better idea of the molecular formula but even deconvolution just gives a list of possibilities.
GC-EI is definitely not the solution for this type of work as you will never be sure 100%.
It's probably "MAM2201". I'll send her stuff directly about it, including a forum more suited to what she does (assuming GC-MS (EI) for drugs is her thing).
SWW
