Empower finished sample set, etc
Posted: Wed Jul 11, 2012 12:38 pm
Hey, when I run a sample set and I won't be at work when it's done, I always include a shutdown/wash method (chosen when you press start). This method turns off the detector, washing the column, then shuts off flow.
When I come back to the system, communication is lost with the system. I can't control anything from the run sample window. I have to go into configuration, take my system offline and then back online and everything works.
One other related question; say I want to stop a sample set that's running, it automatically switches to the shutdown method I selected, is there any way to stop that from happening? Generally if you have to interrupt a sample set and stop it, it means you need to fix something and run it again...
Thanks!
Thanks!
