Surfactant and Silicone Issues
Posted: Wed Jul 18, 2012 6:16 pm
So I have two issues with my HPLC methods that I'm hoping for some insight on.
1) I am analyzing some non-silicone shampoos/conditioners/personal care products to quantitate various components (generally small molecule, nonionic, nonsurfactant). I've been having issues with over pressurizing my HPLC system as (I assume) the high surfactant amounts are depositing on my ss tubing and column. I am running a MeOH/H2O gradient on a C18 column. The original sample prep was to extract in 100% water, but I've switched to an ACN extraction, diluted to an appropriate ACN/H2O solution for analysis to avoid solubilizing the surfactants. I've seen some literature on how to analyze surfactants on HPLC, but nothing on how to clean them off or avoid them altogether.
A) Is there any other known way to avoid injecting so much of the surfactants onto my system?
B) Is there a good wash method I could institute to insure the surfactants don't build up?
C) Are there any other indications that the surfactants are not depositing other than monitoring the
pressure?
2) I am also analyzing some silicone based products, but have always heard that silicones irreversibly deposit onto reversed phase columns. Again, is there any way to ensure this doesn't happen, or to clean out the column?
Thanks!
pressure?
Thanks!
