GC- Negative peaks
I am working on GC system on a product from last one month, now all of sudden there is negative peaks with same retention time. What could be the problem associated with negative peaks.
I have checked down with polarity, leak test etc. and all the parameters are kept same from past one month.
kishan,
Please give us as much information as possible about your system and analysis parameters and repost this in the Gas Chromatography section.
Among the parameters, be sure to note the type of detector and all gasses used in the GC system.
In total there are 33 users online :: 1 registered, 0 hidden and 32 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 32 guests
