TLC solvents...
Posted: Thu Jul 26, 2012 10:38 am
I tried to run a 1D-TLC with two solvents to analyze phopholipids of a fluid. (silica gel plate, 7,2 cm x 16 cm, first solvent (went up 7 cm): 40:10:10:1 chloroform: methanol:acetic acid: water and second solvent (went up to the top - alltogether 14 cm): 120:46:19:3 chloroform: methanol:acetic acid: water)
The problem is that all standards (cholesterol, sphingomyeline, phosphatidylcholine, phosphatidylethanolamine) run with the solvent front on the same level and the sample in consequence hasn't been split up.
I think, I have to vary the composition of the solvents, but I'm not sure in which way.
Do someone have an idea how it could work better?
My second question. After TLC I've to scrape off the spots in order to measure the phospholipid-content (Bartlett). Is it possible to scrape it off from a bought plate or do I have to make a TLC-plate by myself?
Thanks a lot for your answers!!!
Kind regards
Kind regards
