HPLC quantitative analysis
Posted: Sat Aug 11, 2012 11:44 am
Hi
How do you calculate the amount of a compound from a sample ? To be more precise i do know the procedure somewhat but the problem is i've got different retention time for both of the compounds i am trying to determine i.e retention time for both compounds in the sample "X" is different than the retention time of the pure compounds. Does this mean that the compounds aren't present in the sample (sample x) ? For more details i've included the entire question below.
Any help would be greatly appreciated
I've tried to embed the chromatograms as suggested here viewtopic.php?f=5&t=12662 but i've been unsuccessful so far and that's why i've copied the URLs.Sample X (serum) has gone through the following process before being injected into the HPLC instrument: 500 μl of sample X was added to 500 μl internal standard (vitamin A acetate and vitamin E acetate), and mixed well. The mixture was extracted with 1000 μl hexane and was transferred to a clean tube and then evaporated under argon. The evaporated extract was dissolved in 500 μl methanol and injected into an HPLC with UV detector. All analysis were conducted using the same HPLC conditions. With the help of the attached chromatograms determine the amount of vitamin A (mg/l) and vitamin E (mg/l) i ”Sample X” by using peak height
(For all retention times in this experiment, we allow a time window of + 0.08 minutes.)
1. Vit A chromatogram
http://tinypic.com/view.php?pic=n4z4ug&s=6
2.Internal standard(vit a & e) chromatogram
http://tinypic.com/view.php?pic=6p8dq8&s=6
3. Vit E chromatogram
http://tinypic.com/view.php?pic=2vkbwcw&s=6
4. Sample x chromatogram
http://tinypic.com/view.php?pic=2r3ikn6&s=6
