pH shift in ammonium formate buffer
Any body oberves this kind phenomenon ?--pH shift in an ammonium formate buffer ?
A water solution with 20 mM ammonium formate buffer, adjusted pH by formic
acid to pH 6.0, within 2-3 days, pH is increased to 6.2 ~6.3 range.
Ed
Since ammonium formate is not a buffer at pH 6 (check the pKa values of formic acid and ammonia, respectively), it's not surprising at all.
