Correction Factors of related substances
Hello everyone,
i am new in this forum so please excuse me if i make no sense!
to get straigth to the point, we have a dilemma as far as the calculation of correction factor of the related substances of Ranitidine HCl is concerned. Our final product is expressed as % Ranitidine (as base) but our working std is Ranitidine HCl. When calculating the % of the related substance we take into consideration the convertion of Ranitidine HCl to Ranitidine (base) but our problem is ...do we have to make this convertion when we calculate the correction factor of each related substance? I tried to make my point clear, i hope i did. If there is anyone that can help me please answer!
Thank you in advance
Calculate your standard concentration in terms of the base, then all is in terms of that including RS.
DR
Thank you for your reply,
so, if i understood what you said, you mean to calculate my standard in terms of base in order to use it to the formula i use to calculate the correction factor of each RS getting a fixed number, which i will later use in the formula to calculate my %w/w of RS in my product -where i will have to calculate my standard in terms of base again (because my product's claim is expressed as base). Did i understand correcly? Does that mean that i do the conversion (Ranitidine HCl to base) twice or not?
Thank you for your time
You just do the conversion one time.
Calculate your ran.HCl concentration, then multuiply it by the ratio of
base formula weight / salt formula weight. This value is your standard concentration in the data system.
DR
During the validation of RS i calculate the responce factor from the slope of Ranitidine HCl and the Relative Substance's slope. Do i make the conversion then at the concentration of Ranitidine HCl?
Thank you for your kind help!
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 28 guests
