Chemstation- fatal sequence error
My sequence will start and run line 1 to completion, then an error messge pops up "fatal sequence error-- see Log book." The log book has no notation. Data analysis states no data was received for said data file. Agilent's site isn't helping. G1701EA. Can you help?
Try using the "Simulate Sequence" function. Be sure to select the "Entire Method" option when running the simulation. It is very useful for debugging sequences. (I use a similar version of chemstation)
Make sure you have adaquate space on your hard drive.
