How to remove silicone "oil" from injection port
Does anyone know how to remove silicone build-up from the septum in the injection port? I have a SSL injector that has not been used in 2 years but installed and I'm noticing a lot of, what appears to be, silicone oil residue from the breakdown of the septum. It is covering the entire inside of the injection port. I tried a copper brush and acetone and methylene chloride but it still seems to stick around. My peaks have awful tailing that I can't get rid of. Is there any solvent out there that will dissolve this junk so I can restore my injection port?
Ty
~Ty~
Silicones break down in the presence of base.
Ammonia comes to mind. Ammonia in methanol also comes to mind.
best wishes,
Thanks Rod. I have also heard a similar suggestion here around the lab. I think I'll give it a try next.
~Ty~
In total there are 27 users online :: 2 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 25 guests
