Guard column ID matching
Posted: Thu Sep 13, 2012 11:07 pm
G'day from Perth
I am purchasing a 250 * 4.6 mm (5um) analytical SAX column and have multiple choices as to what ID i can get the guard column in. Price wise, the 20 * 4 mm option is the best, compared to the best ID match of 17*4.6 or even 40*4.6 mm guards.
Flow rate: 1ml/min
Mobile: PO4 buffer with MeCN, gradient
I would apprciate any comments on the pros and cons, if any, of choosing a guard with a smaller ID than the analytical column.
i would imagine that with the 4 mm rather than 4.6 mm ID guard, backpressure may be a little higher, but of course with the guard being very short, this increase would be minimal. Sample plug i would imagine would be 'tighter' with the smaller ID guard.....
thanks for any comments
Greg
Flow rate: 1ml/min
Greg
