UPLC grade water or HPLC grade water??
Im running on UPLC for the last month and ive had serious pressure problems....i finally think its the water we are using. I found this article...... http://www.hplc.hu/PDFs/UHPLC_MobilePhasePrep.pdf. It suggests that even though i using hplc grade water filtered through 0.2um filter that this isnt good enough!! has anybody had experience of this??
I think problem with your column? Switch to new column.
Usually this filtration is enough. Check the prefilter of the column.
In total there are 15 users online :: 2 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 13 guests
