can I use Ethyl Acetate as mobile phase for C18 column?
Posted: Fri Sep 21, 2012 7:41 am
can I use Ethyl Aceta as mobile phase for C18 column?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
It's not advisable to go ahead with ethyl acetate as it disturbs the stationary phasecan I use Ethyl Aceta as mobile phase for C18 column?
Yes, you can if you use silica based C18 (polymeric supports will likely swell and have high back pressure). The technique is called "non-aqueous reverse phase"can I use Ethyl Aceta as mobile phase for C18 column?
