Column regeneration overkill?
Hello all. I am new pretty new to using hplc and had a general question about regenerating my column.
I've observed that my retention times slightly shift to higher values with the more injections I make. Once after about 9 injections had retention time had increased. And even when I increased temperature expecting the retention time to decrease, it was larger than the lower temperature. I looked up some normal-phase regeneration procedures. I only had one solvent for the regeneration procedure, but I used it anyways and saw a significant drop in the retention time.
My question is, how often should someone have to regenerate their column. After seeing this I was thinking of adding column regeneration to my method maybe every 6 injections. But I wasn't sure if that was overkill and if I should just reconsider my whole set up.
Thanks for any help.
Hi olufadi1
You are using normal phase? Or reversed phase chromatography?
Normal phase. Stationary phase is silica gel and mobile phase is cyclohexane.
