help please dx lan problem dionex in chromatography system
Posted: Sun Oct 21, 2012 2:51 pm
hi all,
I am desperate. I have a chromatography system, dionex gp50 pump cd20 conductivity detector
the software i am using is the 6.60 chromeleon.
Everything was working fine, but lately there seems to be a failure of communication between the software and the pump/detector. The analysis is starting as it should be and after a point it stops and there is a message that says that
dx lan is timed out!!!!!!!! Sometimes because of a dx lan error i can not connect the pump or the detector.
Any ideas?
i have switched cables but nothing.
thank you in advance
Any ideas?
