Calculate Method Validation Linearity using Empower 3
Hello Everybody,
I am new here, does any Empower expert know how to generate Method Validation Linearity Results using Empower 3 software?
you can get far more than that out of Empower if you purchase the MVM option and take the training...
Without (lots) more detail, you will find a dearth of replies.
DR
I do not have MVM installed, does that mean I could not calculate Linearity then?
No, you can still get what you need, just not quite as efficiently.
DR
DR,
Can you clarify?
Is there a way to generate MVM results without purching the MVM option?
Ace
There may be a way, but you would have to be pretty good at custom field and report method writing to do it. Also, MVM is not all about reports - it integrates sample requirements from numerous validation protocol requirements into a "smallest possible" sample set for running, and it keeps track of what sample results constitute the different portions of a validation report. It saves lots of work and time.
DR
