Agilent 1260- Chemstation last version: print chromatograms
Posted: Thu Nov 08, 2012 9:45 pm
I am totally new in chromatography
and I just started working with Agilent 1260 HPLC, that has the last version of chemstation, I think is B.04.
When I analyze data, I open each chromatogram, check if I have to do manual integration, and then when I am done I go one by one, printing one at a time. Is there any way to print all chromatograms at the same time, after I am done with the integration?
(I know there is an option to let the instrument print after the run, but I prefer not to use it since I might have to manually integrate some peaks)
Thanks!
Thanks!
