Dionex SRS 300 SUPPRESSOR leaking
I have a small leak from the Anion Suppressor.
It seems that it is working well, since it suppresses conductivity to the desired level. But there is a small leak. It doesn't seem to stop though. Is there any way to try and repair this?
you can't repaire it, but there is no issue. many times the salt which is deposited on the outer surface of the suppressor, if this salt is dissolved then this leaking may starts. i have this experience and after some times this leaking is automatically stopped.
