Exporting data in Chemstation after every run
Posted: Sun Nov 18, 2012 10:01 pm
Hello, thanks to everyone on this forum, I feel like I've already learned a lot here. I have a question though. I currently have an agilent 1100 series HPLC (liquid chromatography) with a fluorescence detector and a vial autosampler. I typically am running 96 samples at a time, and the samples are named 01, 02 02, etc. Currently I have to open each result in the offline mode and export the signal from the FLD to a .CSV file for further analysis.
As you can imagine, this is very tedious. I was wondering if there is an easy way to do this with a macro of some kind? I don't really know much about writing macros and the chemstation documentation isn't really very helpful. I also am using the latest version of chemstation if that is important.
Thanks for any advice you can give me.
