Negative peaks/ Inverted Peaks! :(
Posted: Mon Nov 19, 2012 10:11 am
Hi again guys!
I am running a new method with a 3um eclipse c18 plus column. Mobile phase is 95% (2%tea) 5% water.
when i inject the standard diluent (ALONE), which is 20% Methanol (to dissolve the API) and then made to volume with Mobile phase i get three negative peaks. Very clean negative peaks at 4/6 and 8 minutes.
When i inject a stardard obviously including this diluent, the peaks turn the other way and become positive. As you can imagine this is very annoying and making a problem as they can be mistaken for degradents etc..
Any ideas? Heellpppp!
Thanks again.
Thanks again.
