dean switch
Posted: Fri Nov 30, 2012 11:25 am
Can use the Dean Switch in order to connect two GC columns consequently?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
If you want to connect the end of one column to the beginnning of the other, without adding any gas at the connection or diverting any of the carrier gas or sample to a different flow path, then a Deans switch is not what you need. You can use either a press-tight type of connector, or a metal capillary connector.Hi,
