headspace shaking effect
8 posts Page 1 of 1
Dear all,
I 'm looking for a method useful for test the shaking capability of an headspace autosampler.
Could you suggest me a method in which shaking of the sample is very important for the reaching of the equilibrium (equilibrium time is strongly affected by the presence or absence of the shaking)?
Thank you in advance
Greta
Any matrix that tends to separate into two phases or is slow to dissolve unless heated at an elevated temperature and shaken would be an example of a good test.
Of course, this is all mute, unless you have evidence that by NOT shaking you have affected the result of your headspace analysis.
Larger samples will show the effect of not shaking more than smaller ones. A simple test of isopropanol in water using different amounts of sample could be the test you seek.
With these points in mind look around your lab and see what you have that would qualify and try them out.
best wishes,
Dear Rod
"Any matrix that tends to separate into two phases or is slow to dissolve unless heated at an elevated temperature and shaken would be an example of a good test".
Could you be so kind to give me an example for this?
Best regards
Daniela
Candle wax in DMF.
Dear Rod,
Do you have a method for Candle wax in DMF analysis to suggest me?
many thanks for your help.
Bets regards
Daniela
Sorry. I don't. Do you need one? Really?
Hi Rod,
Are you jocking me?
Greta
Restek has a guide on headspace at http://www.restek.com/pdfs/59895B.pdf . This might give you and idea for a system that might require shakiing.
8 posts Page 1 of 1
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
