ph of mobile phase containg water:methanol:o-phosphoric acid
what is pH of ph of mobile phase containg water:methanol:o-phosphoric acid (60: 20:20).
when i prepared mobile phase pH its going down to 2.6. But accourding to paper it should be 4.4.
Can you give me suggestions
Dear chliam
For me that pH = 4.4 looks more like NaH2PO4.
pH = 4.4 is almost in the middle of pKa1 and pKa2 of phosphoric acid.
Dr. Markus Laeubli
Manager Marketing Support IC
(retired)
Metrohm AG
9101 Herisau
Switzerland
20% phosphoric acid ????? :shock:
i am using 0.1% of phosphoric acid
When are you measuring the pH? Before or after the addition of methanol?
i am measuring ph after preparing complete mobile phase ( water:methanol:0.1% phosphoric acid)
Measure the pH before the addition of the methanol, see if it's different.
