Used Q-Tof Recomedation
I am looking looking to pick up a used q-tof primarily for identifications/quantification of relatively small molecular weight compound analysis in food systems. Unfortunately my budget will not allow procuring a new one but there seems to be quite a few options out there for used machines. My primary concern would be getting a system that will be supported for the foreseeable future and isn't problematic as far as needing excessive repair. On the Used Market I have scene several
(prices are approximate)
Waters
-Q-Tof ($40k)
-Q-Tof2 ($60k)
-Q-tof premiere ($75k)
Agilent
-6510 ($110k)
-6520 ($140k)
-6530 ($170k)
I am sure I have missed some, so if there is a glaring omission that you would recommend please let me know
The price for these units spanning nearly 10 years obviously varies quite a bit, but as I am setting up a lab with limited finances I would probably forgo spending more for a newer instrument if an older one has a great track record for stability and only minimal loss of sensitivity and mass accuracy. Thanks for your help!
Bruker especially with their Smart formula software.
