Cholecalciferol Method Development Issues
Posted: Fri Jan 18, 2013 4:20 pm
I am currently working on developing a method for Cholecalciferol in the Vehicle of Lactose NF Anydrous. The cholecalciferol is mixed with maltodextran prior to being compounded with the placebo. The problems that have arisen are as follows.
1. I have not be able to find a diluent that will achieve 100% recovery of the material other than 100% MeOH, which does not match up with the mobile phase (65% ACN, 35% H2O * currently) it was (90% ACN/10% H2O).
2. The lower percentage of organic used the lower the response of the API as well as a much broader peak is achieved.
3. I have tried both C18 and CN columns with different dimensions to ensure that resolution can occur between any degradant peaks. On either column I still run into the first 2 issues. I achieved better resolution with higher water content but I sacrifice peak shape. I have also tried gradients that have been found to not work as well.
4. A quick test was ran to see if the API was dissolved and diluted in 100% MeOH first, then diluted 1:1 with water (Final Diluent - 50% MeOH/50% H2O) would give better peak characteristics. I have ran this test multiple times and have continuously ran into the issue of the peak shape deteriorating if lower organic was used. This time when the organic % was lowered the peak shape looked great for both diluents, but now I am seeing a strange shift/jump or drop in the baseline after 20 minutes of run time. This strange shift only occured with the samples that were prepared in 100% MeOH but was not consistant, while the 1 sample with 50% MeOH/50% H2O as its final diluent gave a flat baseline.
I am at the point to where I do not know what to try next, Any thoughts or ideas that may help?
