front tailing
Which factors can cause a front tailing in HPLC?
for some basic compounds it can be overloading of residual silanols at certain pH
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
Thnks Vlad,
But the analyte does not contain nor basic neither acid groups.
Inject less microliters, see if it gets better.
reasons:
overloading
poorly packed column (with fronting to help peaks with tailing)
diluent effect
solubility effect
tautomerism of compound (not defined "batman peak" for example)
Vlad Orlovsky
www.helixchrom.com
There is a chalk-talk that covers that:
viewtopic.php?f=31&t=18426
Fronting is discussed near the end (about 8 minutes in), but it's best to watch it all to put fronting into perspective.
