peak width software help (xcalibur, and totalchrom)
Hi all, I am sorry to pop on here and first thing ask, but I've searched somewhat extensively on the web and on this forum. I'm a lab tech at a small university and I am testing an experiment they want to try (just separation of some different benzenes in meoh/h2o).
I am using a Thermoscientific Finnigan LC (coupled with MS, but have MS off). The software is xcalibur. I can't figure out how to do peak width at 50%. There is a very brief explanation of peak width in the help, but no reference as to how to view it (I'm not even sure it's possible, although it seems it should be). I can export the chromatogram to CSV and open it in excel, and was hoping to find a simple tool that undergrad students could use to find the peak width @50, but I can't find that either. Ideally, I'd like a free software you can import a CSV chromatragram into, but I don't think those exist.
Secondly, and less importantly. I have a way to get peak width at 50% for our TotalChrom (perkin elmer) on the other LC we're using for the class, but it's a lengthy and annoying process for each chromatogram, which involves running everything, using graphic edit to re-identify components, running system suitability on all of them, then opening the report for each.
I've been working all weekend on the experiment, and unfortunately it's tomorrow and I still don't have a way to get peak width on the xcalibur. I'm hoping I don't get an evil eye if I tell them to calculate it manually with a ruler on the screen.
Very grateful for any help,
Thanks !
I think http://sjsupport.thermofinnigan.com/tec ... CAL_GS.pdf should get you started ;-)
Take a look at the report section, and figure out how to get a report with your peak properties (eg area, height,..) maybe peak width is in there?
Otherwise: call Thermo?
Good luck
Ace
Assuming your peaks are reasonably symmetrical and you can report out baseline width, the width at half height is 0.59 times the width at baseline.
For a Gaussian peak, baseline width is 4*sigma. Width at half height is 2.35 *sigma.
