Empower processing everything in duplicate
Hey all, so the title pretty much says it all... I'm processing everything just fine and everything is correct, but for some reason everything is processed twice, so I have a duplicate of every result, this is especially annoying when reporting tables. Any ideas on why this might be? I've never had this problem until it seemingly came out of nowhere. Thanks in advanced!
"Normal" in the function spot on ea. line of the sample set method followed by a "Quantitate" line at the end can do this. Get rid of one or the other...
DR
DR
Ah, so if I change "Normal" to "Do not process or report" I should be fine then? Thanks!"Normal" in the function spot on ea. line of the sample set method followed by a "Quantitate" line at the end can do this. Get rid of one or the other...
Right. Same thing applies to standards - if they're processed "Normal", tehn you do not wan a "Calibrate" line at the end, or they'll be doubled as well.
DR
DR
Users browsing this forum: lmh and 2 guests
