Anion Column
Hello, does anybody know how to re-generate an Anion /S column? Packing is Silica w/quaternary ammonium ion exchanger. Mobile phase is 4 mM KHP.
Thank you very much.
Raul
Maybe the manual or handbook you got from the manufacturer of your column can help you to do a kind of regeneration of the column, but in most cases that will not work and it is time to order a new column. Sorry.
A higher concetration of KHP and / or a higher pH. But those columns are notoriously short-lived:six months or so in aqueous solution (even if you don't run any samples). Storing in methanol "stops the clock" on the deterioration.
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 22 guests
