regarding bed,column and void volume
can anyone help me in differentiating and calculation of bed volume,column volume and void volume in HPLC columns?
Pie x r2 x length will give you the volume of the column. If you know the packing density and the volume between the particles you can calculate the netto volume of the packing, the bed. The void volume can be messured by injecting a compound which is not retarded. "Retention" time of this compund will give you the volume from the injector through the tubing plus the "dead" volume in the column.
Hope that helps.
Hope that helps.
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
