gradient for dissolution
could someone explain to me why one would do a 30 minute gradient to determine the dissolution of a tablet? The R.T. is about 20min and the peak is huge(no other peaks are present, very good baseline)
Basically 2 possibilites:could someone explain to me why one would do a 30 minute gradient to determine the dissolution of a tablet? The R.T. is about 20min and the peak is huge(no other peaks are present, very good baseline)
- Some other peaks *could* be present (degradation or synthesis byproducts of the API) that need to be separated by that gradient
- The method is just too complicated, as already supposed by you
If the method is identical with the one you use in assay context, it makes sense using it in dissolution testing as well.
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
