Column and transfert line, Varian saturn 2000
Hi, i have a saturn 2000 but I don't know how much column have to be inserted into the mass spectrometer , does somebody know how many mm of column have I to insert into it?
Thank you
Enrico
1 mm of the column should project from the transferline.
Thank you very much for the answer!
Enrico
