Questions about Method Development with Sugars
Hi everyone! I have decided to try the AOAC offical method 982.14 (sugars in presweetened cereal) as my next project but I am having trouble deciding what column to use. I have been researching this site to see which column would be the best choice and I can't decide between the waters columns and agilent columns. And by the way, this would be done on an HPLC with an RI detector. Thanks for the help!
~M
Flip a coin.
Seriously, an amino column from either supplier should work. Go with whomever has given you the best support in the past. In any case, you may have to tweak the ACN/water ratio a bit.
In total there are 10 users online :: 3 registered, 0 hidden and 7 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], John Guajardo and 7 guests
