ECD oxidation
We are running an SRI GC in combination with an automated chamber system in field. Today I noticed both carrier and make up gas cylinders were empty while GC was still running. Does this mean ECD has been oxidized for sure? If yes, is there a chance it might still be usable or it has to be replaced now? Sorry if this topic has been discussed before.
Hiz
There is only one true way to determine this.
best wishes,
Hi Rod,
I've run the system and visually it seems OK; i.e. all N2O and O2 peaks appearing as they should. Not sure if I need to run any sensitivity tests. If yes, how?
Hiz
I assume you run a low standard every now and again to confirm sensitivity?
