GC/MS, GC/FID, and GC/PID for the gas sample with BETX
Dear sir,
I have a question for different detector's quantification results.
Now,
I have tedlar bag sample(it included BTEX gas with 10ppbv(N2 dilution))
We have GC/MS and GC/FI(GC/PID) system to analyze sample.
Concentrations will be calculated as toluene equivalents.
For GC/MS, we have thermal desorption/GC/MS. First i will collect air for 10minutes using accurate MFC into Tenax tube.
For GC/FID, we have cold trap before GC column.
Total concentrations are same if I use three different detectors?
I’m looking forward to hearing from you soon.
Jaehwan Lee
As long each system is properly calibrated (in terms of response vs amount) then they will all give the same result.
Thank you for your kindly reply.
I will let you know our results after try it.
Best regards.
Lee
Are you able to go down to the lower limits required by law for BTEX using an FID detector?
