Residual acetic acid determination in API
Dear Friends,
hi,
I have to develop a method to determine the acetic acid in AIP which is insoluble in water.
We have will known method for water soluble API by HPLC.
When i tried other diluent in place of water,response of acetic acid is very poor and not a perfect peak obtained.
I also tried the the same work on GC,but not achived the result.
Pl. share your experiance.
Pawan kumar
Hi Pawan,
If you can dissolve it in 80% acetonitrile try using a HILLIC method.
Just google "acetic acid by hillic" for a good starting point.
MestizoJoe
Analytical Chemist and Adventurer
Venture Industries
Spider-Skull Island
HILIC only needs one "L"
Searches work best when the spelling is correct! ;)
Haha that's true. Google usually asks me if I meant something else.
MestizoJoe
Venture Industries
Spider-Skull Island
You can try to extract AcOH with water and then test clear supernatant.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 8 guests
