Varian Prostar 330 PDA Wiring
Hi Everyone,
I'm considering buying a used varian HPLC system, but for my purposes will need a PDA detector. The prostar 330 looks like it will fit my needs. The 330 needs a contact closure start signal which it gets from the 210 LC pump, but the manuals I have are not useful as to how this is accomplished. The contact closure signal requires a special cable that Varian used to sell, P/N 03-935716-01, but no longer does. I cannot find it in the Agilent catalog nor can I find any information about how it was wired. Does anyone have one of these cables? Could anyone provide a wiring diagram for that cable? Which pins of the RJ45 connector on the 330 PDA need to connect to the contact closure on the LC pump?
Since it's a contact closure, the PDA's RJ45 output must have one pin set to high (5v?), and one pin that, on contact closure, senses that positive voltage, right? If I were to test the voltage on each pin could I find the active pin? If that works, does anyone have any ideas on how I can find the sensing pin, other than just apply +5V to each one sequentially?
Any help is greatly appreciated. A service manual, if available, would be incredibly helpful as well.
Thanks!
Hi mate,
Here's a few shots of the back of our 210 pump and what the plug looks like. I'm not that confident that I've identified the correct pins tho. The trigger is a paired dark green/white combo. Alas we don't have a multimeter in the lab.
We run the Prostar 330 and 240 pump, both of which are interfaced with separate GPIB cards. The 210 is a backup for when the 240 fails. I'm explaining this as I then have to ensure the 210 can trigger the 330 via the CIM setting for the pump (ie. a start pulse for contact 1). I wrote a "guide" for the lab on how to do this and am happy to share if you want (it made sense at the time, not sure about now tho. ha ha)
Users browsing this forum: Bing [Bot] and 5 guests
