Temperature Control Fault, Muxed ADC error.
Posted: Mon Jul 15, 2013 8:06 pm
by BIGTVO
Hello all,
I just did source cleaning on my MS 5973 and after I installed everything I am getting a Temperature Control Fault Muxed ADC error when I try to do a autotune.
How do I go about troubleshooting this?
Re: Temperature Control Fault, Muxed ADC error.
Posted: Sat Nov 09, 2013 9:23 am
by freddiespedalo
Hi BIGTVO.
Did you get anywhere with this?
I am attending a fault on monday with the same error message.
Initial fault was temp sensor error on the source (intermittently reading 512C) - we replaced the heater/sensor assembly and the result is the same fault as yours - not been in front of it yet - but wondered if you had a resolution for yours.
Can't see any manual refs for this fault.
Cheers,
Fred
