Cleaning the fluidic path
I want to ask you if I could cleaning the fluidic path with ACETONE to a GPC system by Waters with refractive index detector 2414.The reason for I ask you, is that I make an analysis of copolymer styrene-acrylonitrile with a big molecular weight (the system is dirty now)and the common solvent to cleaning the system is acetone.Could I used to my system without damage the GPC?
Thank you
Chem.eng Ileana Curca
Please don't forget to disconnect your columns before you rinse with Aceton.
In total there are 17 users online :: 2 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 15 guests
