which fragment ion should be used for quantification
generally base peak, or the second largest peak?
I usually choose one that is unique and hopefully quite larger. A unique fragment makes most of the other stuff you don't care about vanish and a large one gets you the sensitivity you want. You should also monitor some others that are characteristic to your analyte so that you don't identify a coeluter as your analyte. The ratios of the fragments should be characteristic of your analyte. Generally, even isomers have different ratios of the fragments generated.
Good luck!
make sense. thanks.
Good luck!
Users browsing this forum: Google [Bot] and 1 guest
