which fragment ion should be used for quantification
Posted: Tue Aug 06, 2013 10:40 pm
generally base peak, or the second largest peak?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
I usually choose one that is unique and hopefully quite larger. A unique fragment makes most of the other stuff you don't care about vanish and a large one gets you the sensitivity you want. You should also monitor some others that are characteristic to your analyte so that you don't identify a coeluter as your analyte. The ratios of the fragments should be characteristic of your analyte. Generally, even isomers have different ratios of the fragments generated.
Good luck!
