Question about Shimadzu LC Solution and calculus
Hello again,
I have a question for the LC Solution users.
Is there a way to use calculation formulas in the LC Solution software?
I have 4 peaks on my chromatogram and I would like to know the percentage of the first two from the total. Is there a way to add a parameter that can be calculated from the pick areas or do I need to do it afterwards in excel?
Thanks a lot to all of you who can help me with that.
It is not possible in the LC Solution software.
The new LabSolutions DB software has the features of Custom Calculation parameters. The template looks like excel and you can prepare your template with calculations.
Users browsing this forum: Google [Bot] and 1 guest
