regarding analyte carry over
I am using phenomenex kinetex c18 column for ochratoxin A analysis. Mobile phase(Acetonitrile/2%acetic acid=1:1);Flow rate-1ml/min;
when I used to analyse it I am facing carry over problem. I am not sure what is causing this problem? please help me out from this issue.
Please check your autosampler or injection valve first, than check the Connections from the injection System to the column. It can be caused by extra column effects.
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
